I'd been considering a benchtop lathe for a while and when I found an unused Central Machinery 7x10 at a garage sale for $100, I bought. I got it home, cleaned off all the packing grease (cosmoline?) and proceeded to get all the slack out of the carrage, cross slide and compound slide (or as much as was possible). I also bought and installed a quick change tool post with extra tool holders. I also have a camlock kit coming for the tailstock.
I used some 1/2" steel rod that I turned to a fine point to make a tool for tailstock and cutting tool alignment. So, I pretty much had it all set up.
Yesterday evening I mounted some brass stock to do my first small project. Turned on the power switch (which lit up like usual), selected forward and slowly turned the speed pentometer up... and nothing
I found a trouble shooting direction for mini lathes and proceeded to try and sort it out. Checked continuity of the fuse and holder, check. Tried to check the lighted power switch but get continuity when the directions say I shouldn't. Same thing with the pentometer, continuity when I shouldn't although the output check showed it was giving the correct ohms when running that check.
So... after some consideration, I've decided to takemy lumps and get a different lathe. I want the ability to carry it to a metal welding table but store it away when not using so weight and size are considerations. Looking at the Grizzly G0768 and it seems to fit those criteria.
If you are near Houston southwest and need a HF mini for parts, it's yours for free (too heavy to ship).
Dennis
Dennis
