- May 4, 2018
- 143
Saaay, what's the story on that tailstock for your rotary table? Did you make it? I've been thinking about making one...
MetaKey
I made the tail stock center. Nothing fancy but it works. If you want I can post a closeup pic.Saaay, what's the story on that tailstock for your rotary table? Did you make it? I've been thinking about making one...
MetaKey
That is the same as mine. When i put the harbor freight motor on it, i no longer had a flat head to mount the idler bracket on so I had to get creative. The belts don't align perfectly, but they work.Hi Chris, I found these pictures online- looks very much like yours:
Mark
The center is made of steel that I turned and then hardened. The other parts are made out of 1 inch aluminum. The two small bolts tighten the center in place once I use the bolt at the back to push the center toward my work. Not elegant but it works.
