author=Highpower link=topic=1541.msg9909#msg9909 date=1302574209
author=Zigeuner link=topic=1541.msg9831#msg9831 date=1302549846
A few years ago, I got a Lincoln SP 175 + MIG welder and traded the Lincoln TIG in on a Miller Syncrowave 200. Both of those are perfect for the home shop.
I'm not trying to hijack the thread here - but just had a quick question...
Zigeuner, do you ever have any problems with stray HF from your Syncrowave? I can't use mine when the wife is on her computer because it drives our home network router NUTS!
What Tony Wells says might work. Also, I presume that you have the manual for the SW 200. Figure 7-3 on page 35 of the manual has a great diagram of proper techniques to stop HF migrating out of your shop. Take a look at that and see if you get some ideas from it.
I haven't had any problem since I live on 2 acres and my shop is in a barn. It's about 75 feet from the welding area to any computer so I haven't had a problem.
Beyond that, my power comes from the back of the house at a 200 amp service entrance from a pole just outside of the side fencing. From that box I took 100 amps to a subpanel inside of the barn. There are four really large USE cables underground that feed the barn: Two hots for 240 VAC plus a neutral and a large ground. Besides that, there is a 6 ga. copper ground from the subpanel connected to a rebar in the foundation that's about 6 feet down. I did all of that in 1979 when the barn went in.
The point of talking about that is that the barn electrical, although it comes from the house box, is rather well isolated from the house circuits and very well grounded. If you are using a circuit in your house and working inside of the garage, say, I could see where you would have an issue.
Interestingly, I do hear a touch of HF static in the barn if, and only if, I have the radio on when I'm working. It lasts only for the startup on the SW 200. I asked my Miller dealer about that and he said that, unlike a straight sine wave welder, the SW models only need HF on start since on AC, the arc is maintained by the square wave balance function. That's what he said anyway...and as I said, I can hear the HF at start for a second or less and then it drops out. For the record, I do recall that the Lincoln Idealarc TIG, which was straight sine wave and which used HF on at all times during AC operation would cause the radio to make constant static during AC welding - but for the reasons mentioned above, it never bothered any computer usage.
So, my take on the issue, which I understand is not an uncommon problem, would be that you are too close to the computer with insufficient grounding. Take a look at the manual and let us know what you think.
Maybe you could tell your spouse that you need an outbuilding to improve this situation....heh heh.
Hope this helps.
