- Feb 27, 2023
- 39
I have a Vevor 7 x 12 mini lathe and I am having difficulties finding a replacement gear, one of the two gears on the forward/reverse lever that transfers power from the spindle to the change gears. Below is a pic, not my machine but same. You can see the handle that changes from forward to reverse, and the two white nylon gears mounted to it, secured by large hex head bolts. The gear I need to replace is the one on the right. It is .885" diameter, 20t. 0.278" thick, 0.392 I.D. Part of my problem is I do not know what that particular gear is officially called. Vevor doesn't put out much of a manual and no drawings or parts list, and getting help from them is like pulling teeth.
Being that the gear is nylon or some other plastic, and is very vulnerable to someone ignoring the instructions to put the machine into all stop before changing directions of the feed screw, I KNOW there have been a lot of these replaced, so somebody must be making them. Below is a pic of my trashed gear. I guess you would call it the feed screw reversing gear? I don't know.
Any help appreciated.
