Need tips on drilling a long thin through hole
tjb
H-M Lifetime Diamond Member
May 3, 2017
2,027
I need to drill two holes in a piece of 5/8" aluminum that measures 2" x 4 1/8". The holes need to be 3/16" and go through the 4 1/8" length. They need to be very accurate, so I plan on doing the operation on my mill.
I have found several bits to choose from but don't know what parameters to select (material, point angle, etc.).
I've never tried to drill a hole that deep and narrow, and life would be difficult if the bit breaks off in the hole. Any tips to help avoid a catastrophe? Drill speed/feed rate/etc.?
Thanks in advance.
Regards,
Terry
Could you drill from both ends and meet in the middle?
Thought about it. Would rather avoid it because that would introduce a potential misalignment. I see that as a worst case scenario solution that I hope I can avoid.
Thanks
Guhring parabolic drill would work nicely .
Any one in particular? MSC Direct lists 12 of them. They range from about $15 to $476 with all kinds of different parameters.
Thanks
Good luck, TJB. I would not want to try that one if the drill must stay closely accurate to the center line. Someone who does gun barrel boring might have the best advice...
Yes , they are expensive . If you have their big book they explain what performs best for special applications . I don't have the book in here at work . They make deep hole drills for aluminum though , one of my past jobs required drilling 12" deep thru aluminum for a drone antenna ( SP ) . I pecked it on a cnc lathe with no problem .
Thanks, Bob.
Hopefully one of our riflemen will offer some advice.
Regards,
Terry
Wonder if I could improve my odds of success by starting with a 64th under screw machine or jobber bit. Then following with the extended length?
Anyone?
Thanks,
Terry
When you state " needs to be very accurate " , regarding diameter , true position , parallelism ? All of the above ?
