- Apr 4, 2013
- 884
I'm working on a DIY kit for Glass and Magnetic scales and have a few design decisions to make:
1. I can use PCB-mounted DB9 connectors that will look neater and more rigid, but since different scales have different pinouts, that means that it will be necessary to modify the cable to fit the adapter's pinout (re-solder some wires). Alternatively, I can go with 4-pin headers and panel-mounted connectors. That way the scales will stay stock, but there will be a bit more work with the connectors. Also, the second option is about $6 more expensive (for some reason PCB mounted connectors are much more expensive)
2. I can use a single resistor network to pull down all 8 input pins, or 8 individual resistors. Since all of the glass and magnetic scales I've ever encountered use some sort of sourcing output, this will work fine. Unfortunately many rotary encoders use sinking output. With individual resistors I can add a way to select pull-up or pull down option per axis input; with the network it will need to be either all up or all down.
Practical implication is that if I go with panel mounted connectors and a resistor network the kit will cost around $50 + shipping, if I go with individual resistors and PCB mounted connectors, it will be closer to $60 + shipping (and will be more complicated). I'm leaning towards simpler is better. Do y'all have any thoughts or strong opinions?
Also, to pre-empt some questions I can foresee:
Yuriy
- The kit will run the same firmware as the pre-assembled board but will have only single-ended inputs (A' and B' lines on differential scales will not be connected; scales will still work fine).
- I hope to have it ready by the end of April, assuming I can get the boards dialed on the first revision (the PCB fab house I use has 2-4 lead time).
- I will likely try to do a "beta" batch first, so let me know if anyone is interested in participating.
- Hardware and firmware is not open source, but I will post the schematic and scratch-build instructions as well, since all of the parts are obtainable in through-hole configuration.
Yuriy
