- Nov 2, 2012
- 415
Note that if you want to use propane (which is way, way cheaper and seems to last forever), the standard acet hoses may not be compatible (you need properly rated "T" hoses) and the proper regulator. You can get a pound of 1/16" bronze rod and a pound of flux (both Gasflux products) for about $17/$14. I also popped for the fancy kevlar (?) hoses since my brazing is mostly bicycle frames and I like feeling free to move around, but they are much less tough than standard hoses. Acet for my skills is way easier to control for brazing thin-wall tubing, but for general heating or if I was going to build something bigger like another lathe stand, I'd grab the BBQ tank, a bigger tip and probably some thicker fluxed-bronze rod. The Gasflux rinses off in warm water if the project isn't too big, though.
