Need help.........
teamcow550
Feb 12, 2022
6
I have a very old Central Machinery mini lathe, Model # 1679. It's been good to me, but the rack teeth are worn out. Anyone know where I can find a replacement part or somebody that has used parts for these lathes? Thanks in advance for any help..............
I think Central lathe is from Harbor Freight tools. I would call them.
Probably impossible to find the exact part- what about flipping the rack end for end? Usually the worst wear is near the headstock
You might be able to fit a rack from another lathe like Grizzly but compatibility is a crap shoot
Might be a long shot, but does McMaster Carr have anything close you can modify?
We have about 20 chunks of racks about the right size.
No clue what they were for, drill press table or lathe...
Post photo of your with some measurements.
In the for sale section there should be photos of what we have.
May be possible to make it work...
Sent from my SM-G781V using Tapatalk
Pull the rack off.
Rack is commonly available. Post a pic of your rack.
Look at the mcmaster carr website and try to match a peice of rack.
Keep Posting.
What does the pinion gear look like? Take pictures and post.
This is not hard, we will help
.250" wide, .500" tall, teeth are approx. .156" center to center
HF does not do parts based on their website. I received an email the other day that said you need to call them for parts.
Replacement Parts
Download the Parts List
Harbor Freight In-Stock Parts List PDF
Find Your Item
Identify the brand name and item number of your product.​
Find the Part Number
Locate the required part and part number for your item. The part number is required when placing an order.​
Call to Order
Call a Harbor Freight Parts Specialist at 1-800-444-3353 to place your order.​
PREDATOR: 3500 Watt SUPER QUIET Inverter Generator
Don't See Your Item?
Even if we don't stock replacement parts in our warehouse, we can special order parts for many brands. Download the special order list.
Harbor Freight Special Order Parts Product List PDF
Check Back Frequently
If you don't see the parts you're looking for, check again soon. We are constantly expanding our available replacement parts.​
Replacement Parts
Let's see the drive gear, as this doesn't look like a plain straight tooth rack.
