Hi,
I'm going to try to make some bucket pins for my CAT 314LCR excavator.
I called CAT-- and they told me the pins are very hard- much harder than the bushings they ride in (this was different information than I had heard!)
Anyways, I found some 4140 65mm Quenched and Tempered rod available online--it's expensive but much less than CAT charges for their bucket and other excavator pins.
-- so I was thinking of buying some of this 4140 rod stock, cutting it to length with my band saw, and drilling holes in the end for bolts to hold it in place on the machine.
Question: this material (4140 quenched and tempered rod) has a Brinnel hardness of 294 which the seller (Parker Steel) tells me is equivalent to Rockwell 28-30. --- Can I cut this stuff with my bandsaw and drill it HSS drills?
Thanks in advance,
Bob
Thanks in advance,
Bob
