need help please
There was a pin in their about 1/4 of a inch. I had to drill it out. Maybe I didn't drill it out enough. I didn't want to damage the shaft. I'll try to drill it more if you thank it will help. Is that the only thing it would be. Thanks Craig
The shaft is held in place by the the bronze bushings on each end of the shaft. The bronze bushings are held in place with tapered pins that are driven in tangent to the side of the bushing. So you have to drive the pins out, then drive out the shaft, pushing the bushing out. The other shafts are held pretty much the same way.
At least this is the way it is on my QCG box. Looks like yours may have set screws..
Ken
