Here is the picture of the current setup. I wanted the vac to stay with the vise wherever it was because I was used to holding the vac hose at the chuck in same place so much. I will mount a one inch rubberized ball on each side of the spindle base (Off the table) so the vac can hold where the end mill is for larger things later. Also the mounts at the spindle base sides could be used for directing coolant.
I was able to get some of the links with "Make and Offer" on eBay for $7.50 each so that helped the cost. But I did buy more than I currently need, thinking of the coolant setup later or dual vac hoses both sides.
It is on my Rong Fu 31 CNC. I also have a Bridgeport that I may put same setup on although I don't use the Bridgeport as much anymore since I have the Rong Fu CNC.
Can also see my Bridgeport vintage quick change set in the R8 taper. I can change tool there and not need to touch the drawbar. I have a nice array of those Bridgeport quick change parts now, have been laying low about it the last years to avoid competition buying them when they come for sale...
