Abrasive wheels will tend to clog up when cutting aluminum same as a grinding wheel will.
Get e relatively FINE tooth blade for cutting the small diameter rods you are working with otherwise it will grab and stall your motor with very bad things happening after that.
I would think on the 185 mm (7.25 Inch) blade for that saw you will want no less than 80 teeth, more would be better.
The last thing you want is for the diameter of the rod you are cutting to be able to fit between (2) teeth).
The general rule for teeth is to have at least 3-4 in contact if at all possible more even better..
