- Feb 8, 2014
- 11,176
Let's start out with the Anilam power supply. Is this the computer supply that is dead? Maybe the 5V supply? I powered mine up for a while with a 300 watt ATX supply. That is the computer supply over on the bottom left of my panel (that's falling off the wall, I should have used Gorilla tape), with the big ball of red and black wires wire-nutted together. I just fed this to the original computer supply 5 V terminals. It got me back up and running until the encoders went south.
Your original servo drives probably are OK. Is the 100 volt servo power supply still working?
Just a note, the encoders are inside the belt housings, driven by a small, really oddball, timing belt driven off of the lead screw. I don't remember what the PPR is on them. The tachs on the motor are feedback to the drives so they can figure out how fast the motor is turning, and have nothing to do with positioning.
The 7i77 Mesa card will run your existing drives. They take a +/- 10 volt command signal. If you have glass scales, you may be able to feed that directly to the 7i77 card for positioning, assuming they have a standard 5 volt quadrature output.
EDIT: I don't know what your budget is, but if you want to set up exactly like mine, I'll give you the software.
