So glad to have found this site. Many of the other ones are intimidating to a newbie. I need some advice and I would sure appreciate anyone’s input on this. Please bear with me.
I am looking to find out what lathe to purchase as a starter lathe. I am having trouble finding a machinist that can do what I need in a reasonable time frame and at a reasonable cost. I have a fellow that has done work for me but he gets so busy that he just doesn’t have time. Other shops are either too expensive or won’t take such a small job.
My only lathe experience is on an AAMCO 4000 brake lathe resurfacing brake drums and rotors. However, I am a good student and will learn.
I need to make prototypes until I find a design that does what I want. Think .177 or .22 air rifle pellets. You know the ones. They went into the air rifles we shot as kids. They were hour glass shaped with flat heads, pointed heads and round heads. My prototypes will look like those, but will be scaled up to between 2 inches and 5 inches in diameter with a maximum length of 10 inches. I plan to experiment with different tapers and different head designs. Additionally, the bases may or may not be hollow. If hollowed, they will have different size cavities with different internal tapers. The material I will use will be either aluminum or a zinc/aluminum alloy like ZAMAK.
Once I find what I like, I can rough cast the pieces, and then machine them to size. I plan to use aluminum rounds for my prototypes. I would need to make 3 or 4 of a design and test to see if they are suitable. If not, I would change the design and repeat the test. Once I land on one I like, the most I would make at a time would be 30. Keep in mind that this is for a hobby and not for production so there is no deadline to meet.
So, given the above, what machine would be a good starter? To me as a newbie, it seems that one of the Grizzly 7X14 ones would work. However, I worry about buying too basic a machine and deciding to upgrade in a year or two because I get into it. Further, if I spent more, might I get a more capable machine with features that I might grow into?
From what I am understanding, I might need a taper attachment to make the hourglass shape, so I must include that machining capability into the unit I would buy. I am not opposed to a used machine, but not knowing what to look for would put me at a disadvantage.
Thanks so much for reading this and please let me know what you think. Please let me know where to look and what to watch our for.
