Need good multimeter
My boat mechanic normally charges $150 and hour. He stopped by yesterday and helped a bit, gratis. I had the exact meter mentioned in post #7. It had worked before but NOT yesterday. Not having a working multi-meter on hand will end up costing me BIG TIME. Now I got to have the dealer stop out. They get $250 just to show up.
So, that $300 for a fluke would have been money well spent. I won't make the same mistake twice.
I think you made the right call :encourage: The 114 is a fantastic multimeter for everyday troubleshooting!
I bought a Klein voltage tester to replace my Ideal Vol-Con that was still working but after a couple of decades was pretty beat up. The Klein was a total POS, literally started to fall apart after only a few months. Other poorly designed "features" like the flashlight that would switch on in the tool bag and drain the batteries, sealed its fate, landfill...
Like the Fluke , but the probes are junk. Why they build a two hundred dollar meter and put harbor freight test probes with it is beyond me.
My volt ohm amp meter is a POS. It was not working today when I needed one. GRR
OK I see prices from $50 to $1200. Most of my work is with 12 and 24 volt on boats, cars, CNC mills, general machine work. Plus quite a bit of testing for voltage present on 110VAC and 220 VAC.
What's a good choice for a new multi meter? Try not to break the bank, but stay away from el cheapo.
I picked up a Fluke 117 about a year ago on Amazon. Paid $185 on a promo, it’s listed now for $233. This unit is designed more for an electrician than for an engineer as the precision is not quite what some of the other models offer, but it includes a built in non contact voltage detection feature which is nice for AC wiring work. It’s very solid and I’ve been pleased with it. On a related note, I picked up this case for it and fits perfectly: Caseling Hard Case fits Fluke... https://www.amazon.com/dp/B07147SS96?ref=ppx_pop_mob_ap_share
I don't like the non contact in the meter. I find the simple hand held to be easier to deal with.
That's just my opinion.
If anybody here did not already know, I am a cheap a$$.
I put the order in to Zoro for the 117, then went looking for the 20% off coupon that I have come to expect. Could not get a valid one on short notice.
Amazon had a similar meter, the 116, for a good price. So, went that way.
I hope you get a real one. Lot's of fakes on the top Mits, and others.. So knowing the source company is important. Lot's of scammers, and cons out there.
With all of the modern electronics one should be able to get good meters for very little. All of the functions are now done on a single IC. Today the price it is probably all about good packaging and branding. Fluke is the big name and makes nice products, but I suspect that today there are many other brands that do the measurements with as close an accuracy that you will never observe the difference. One simple characteristic that is commonly overlooked is how difficult it is to change the battery. Other modern features include True RMS, Capacitance, Temperature, and for some signals Counter, frequency, etc. For these things you might want to note the frequency response spec.
I have several older model multimeters and of these, I have multiple copies of some of them. I have had them for quite a while and some models are not made anymore. Consisting of: A good Fluke 115, Metex N-3800, MasTech MAS-345, Simpson style, and others. The Cheap HF give away version did not hold up long. Maybe some of their better ones would. Good leads are important as the wires commonly break at the connectors as did the cheap HF machine. I use these meters for various applications and some are permanently wired into ongoing experiments. I have other equipment and so seldom use the features like frequency response and counter. If I want to know capacitance, inductance, or impedance accurately, especially at higher frequencies, I use a better machine.
Hence, for everyday uses can employ almost any meter. This summer my Central Air went quit, I repaired it. For this I found having three meters with Temperature Thermal couples, and scales, for measuring the refrigerant line temperatures to be essential. When building electronics I found the insert-able connector for testing bipolar transistors to be very useful. While the fluke is very robust and reliable, it did not do either of these measurements directly. The old, non-electronic Simpson meter turns out to be able to measure things that electronic style meters could not. Sometimes it is best to have a simple measurement. A few years ago, the power system for my electrostatic air cleaner failed. It turned out to be a high voltage rectifier failure. Only the Simpson style meter could could measure the diode reverse current/voltage characteristics correctly to tell if a diode was good.
Price wise, you should be able to get very reliable modern meters for ~<$70. The $25 one that
them.
https://www.amazon.com/gp/product/B071JL6LLL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I only paid $20.99 so I don't remember if it was a sale, or it was that much less than it is now.
mentioned looks pretty good and does have a temperature scale and comes with a thermocouple. Since he gave his testimonial I would not hesitate to try this for general purpose measurements.
Dave
I have fancy meters, but most of the time I use a cheap Radio Shack analog one. What makes a meter really useful though is having good probes that accept screw-on alligator clips- you would not believe how handy that can be sometimes- safer too in some cases
