- Jul 1, 2012
- 1,356
Check with Busch, I believe they told me it had been stress relieved once already. When I cast them, I get them high temp stress relieved after casting and then rough machine them and then high temp cook stress relieve them again. That means heat it to about 1100 degrees and cook it for 2 hours, lower heat to 900 to cook for 2 more hours, lower to 600 deg for 2 hours, lower to 400 for 2 hours and then shut off the heat and let it stay in furnace for 2 hours...then let it cool to room temp. You can screw around and make a home made oven, but I have found it to be unreliable, so send it to a pro. They will set it on steel plates usually at the airy points or 30 %. Some will drill and tap a hole in one end and hang it in the furnace. I have to scoot...more later. Rich
