- Mar 26, 2018
- 8,756
Hey all,
I've gone through two Little Giant, pumps. It seems they last about a year.
I can't afford to be cheap anymore.
These little pumps are designed for fish tanks and small water features. Not for oily water and crud.
What are you using for your mill, lathe, band saw or surface grinder?
I made this tank a few years ago. The dimensions are;
20" long
12" wide
18" high
Thanks for your advice.
Edit: Are these any good?
20" long
12" wide
18" high
1/8HP Filtered Coolant Pump 8180 shaft 180mm 7", 1 Phase 110/220V, Bore 1/2" NPT | eBay
Length (flange to bottom): 180mm (7"). It is suitable to driver liquids such as water, coolant, light oil and other clean, non-aggressive matters liquid to cooling or lubricant applications. - Patented design to avoid liquid over flooding.
www.ebay.com
