It has been about 15 years since I sold my Sheldon and I have forgot some of the things about it, the gear train being one of those things.
I want to point out a few things about the feed gear train that some of you may know and some may not.
There are two gear paths or trains on the Sheldons with the QC box shown in the picture. These produce 2 different ratios of the spindle to the QC Box input.
In the picture below, the idlers are labeled. These transfer motion from the gears on each side of them.
The two trains are labeled A & B.
The pitch diameter of idler gear 2A must be such that when the shift lever below is in the A position (down), gear 2A is engaged and gear 2B is not.
The pitch diameter of idler gear 2B must be such that when the shift lever below is in the B position (down), gear 2B is engaged and gear 2A is not.
The rotation of the spindle is transfered from the spindle gear to the reverse tumblers to the stud gear at a 1 to 1 ratio. (The stud gear rotates at the same RPM as the spindle gear.)
Gear #2A #2B are idlers They transfer the rotation of the Stud Gear to the QC input shaft and cause gears 1 & 3 to rotate in the same direction.
Gear train A gives a 1-8 reduction (12 teeth to 96 teeth) to the QC Box input shaft.
Gear train B gives a 1-1 ratio (32 teeth to 32 teeth) to the QC Box input shaft.
Though other gears could be used in the 2 gear trains, the ratio of spindle rpm to QC box input shaft RPM must be maintained for the QC chart to be correct. The gears shown on the exploded parts drawing provide the spacing and ratios for the chart on the QC box.
Charlie
