D ddickey H-M Supporter - Gold Member H-M Supporter Gold Member Joined Apr 21, 2016 Messages 3,643 Aug 24, 2016 #21 Discovered the feed gearbox is leaking also.
B British Steel Forum Guest Register Today Aug 25, 2016 #22 The leaks are like on Triumph motorcycles - they're there so you know there's oil in it...
T Tozguy Active User H-M Supporter Gold Member Joined Feb 15, 2013 Messages 2,963 Aug 26, 2016 #23 ddickey said: Discovered the feed gearbox is leaking also. Click to expand... My lathe leaks oil also. I just keep an eye on the oil level glass and top up when necessary. My chip pan has a drain that goes into a container.
