- Aug 29, 2019
- 1,049
The keyway is for more gears that is why it is called a cone gear shaft. those gears are slid on from the left side of the shaft and held tight with a snap ring . hence the snap ring grove on the left side of the shaft. if you understand how a quick change gear box works you know what the reason for the cone gears are.I don’t understand your statement that “what appears to be a mandrel with gear on it is actually a shaft that has a gear made into it”.
Why would both the shaft and gear need keyways if the gear is made into the shaft?
