I figured there was some math that I could do to make sense of it all. Brino, Ive got all that information what is the relationship between them or ratio(s) that I am looking for, is there a chart for this, or even search terms that might lead me in the right direction?You will need to know:
- the tooth count of every gear in the train (including the spindle gear)
- the layout of the gears (simple vs compound, as the math is slightly different)
- the lead-screw pitch
- the tooth count of all the spare gears that can be swapped in
Did you get the answer to this?First: Does anyone know what kind of lathe this is, I can find no names
Hey thanks! No answer, and honestly not that worried, I thought maybe someone knew off hand and that would help hone the search for answers but as far as i can tell the only numbers on it are for the forward reverse switch. No casting marks or anything ah well.Did you get the answer to this?
You could look for numbers on the bed.
Welcome to THM
