My week this week, my workshop videos.
No, its a twin! Just spotted the finning on each side!, mine is a twin citroen 2cv car engine! and you may have given me an idea!!
I tried everything to stop that grass deck clutch slipping, eventually we gave up and just usedd it for trailer work, but I had the drive coming from the flywheel bolts, which was a mistake, as I had replaced them with long allen bolts, and they always came loose eventually. In this incarnation, the drive comes from the flywheel where a plate is bolted in place of the clutch cover. Onward and upward, the 2cv engine is 29HP.
This week I actualy finish the exhaust I have been procrastinating for nearly two weeks over it, and as my late mate Alfred would have said, in his thick Dutch accent, procrastination is the thief of time". I will do better now that is out of the way!
Phil, in unseasonably mild East Yorkshire.
The last gasp up to the holidays, but I gopt far more dome than I thought I would, and have got even more ideas for after Christmas, I will be back in the shop in early January, unless it snows, in which case it is anybodies guess as the Langtoft road is particularly treachorous in snow, and it can block up and be impassable in less than 30 minutes! As I type this there is a storm brewing which will bring Greenlands weather straight onto the west coast of the UK, so snow could be a distinct possibility! Have a good holiday and keep safe! All the best! Phil, in a distinctly colder East Yorkshire
Hope you have all had a good time and are refreshed and relaxed and ready to brave the weather and go back to work? No neither am I!! I am taking eldest back to Uni on the 6th(thats the plan at the moment anyway) and will be back in the workshop for more fun and games on the 11th, Thanks you all for watching, please subscribe and comment, and all of you stay safe and lets have a better 2021!
Phil
Well folks, I dragged myself back to work sftr a pleasant Christmas break, got the air filter finished, and made progres generally, but then, the starter is no longer able to spin the engine! that will teach me not to to fit new rings, and grind the valves in! Too much compression for a starter that is designed to start a 15hp single cylinder engine! I think I have pushed the boat out too far, and too fast, and then tried to ump in, and the obvious has happened! The new starter arrives tomorrow! Thanks for watching, and a strappy new year to you all!
Phil Slip sliding away on the ice in East Yorkshire.
Its on! The week went quite well after I stopped procrastinating and just got on and did it! Another breakthrough was the fact that I realised that the vee belt was dragging in the pulley, and stopping the engine spinning properly at start up. This is the belt which is the correct size for the clutch drive, but is obviously too tight for jockey pulley running, I need to see my belt man and get one a couple of inches longer. Thanks for watching, please like and subscribe!
Phil, In frosty but fine East Yorkshire!
Another week of finishing off and troubleshooting on the Toro 2CV. I eventually got to the bottom of the carb fault, but it meant taking the carb body off again, which means it is going to get a thorough clean and shakedown before it goes back on. Thanks for watching, and don't forget to subscribe, like and comment!
Phil, in soggy East Yorkshire
