- May 3, 2017
- 2,029
My compressor is outside under a shed on the right side of my shop. I have a large holding tank inside the shop on the far left - about fifty lineal feet from the compressor. All lines run up the right wall, across the beams, and down into the tank. There is a drain line with a ball valve coming out of the bottom of the holding tank. Compressed air comes out near the top of the tank, immediately into a filter, and then throughout the shop. I try to remember to purge the system every month. It's amazing how much water comes out the bottom of the compressor AND the drain line at the bottom of the holding tank. Filter changes occur about once every other month. You might need to change your filters more often. (I've been told holding tanks are very helpful in water separation. Compared to the system I had before, that seems to be the case.) Let me know if you'd like pictures of the way mine is set up.The humidity here is about the same as Madison. I read its best to put the filters as far as possible from the compressors but before the first drop. I'll have about 5 feet of line between the compressors and the filter. Maybe it will help.
Jay
Regards,
Terry
