Man, what an exhausting weekend- I knocked out three garage projects back to back. Exhausting yet somehow so satisfying because despite a few minor challenges it was all a 100% success and I didn't even lose an eye. In Ice Cube's words "today was a good day".
So it all started with this SnapOn wheel balancer I picked up that had been in storage for about 4 yrs, whether it worked was questionable due to lots of rust etc. It runs off of SnapOn batteries or the AC adapter but the guy didn't have either. Anyway, I got it cleaned up, de-rusted etc and wired up to my Craftsman C3 battery and whatdaya know, it lit up like Kitt after being burried in the sand for a long time. I go grab a spare tire off one of my cars and realized the three cones it came with are too big for the hub bore. No problem I say to myself, I can make a cone myself.
Oh wait, crap, I realized I had the lathe's top apart because I was taking measurements to eventually make a beefy compound slidemount. These 9x20 lathes have a very wimpy 1/4" thick 2 bolt mount.
OK so let's make that first and then make the cone. So after the CAD/CAM work I started the fun part. Cut out a chunk of 5/8" CRS steel plate
Pick up the the edge of the workpiece and drill a hole for all future operation tooling to enter the stock. My first time CNC cutting steel.
Shape the part, using a corn-cob rougher and adaptive clearing, DOC 5/8", WOC .005, 5 IPM, 1200 RPM:
Once I got close I used a 4 flute endmill to creep up .002 to .008 a few times on the diameters (using pocketing operation) due to machine/mechanical error etc and I wanted a very nice and tight fit without slop in either the inside or the outside hole- both radially and axially:
The effort was well worth it:
Flipped it over and flycut the surface:
[/url]
Comparison old vs. new:
Drilled, counterbored and bolted in place, this took a while, especially grinding the regular nuts into T nuts and using an endmill to counterbore
I really like the heft of the new mount. The only issue is that if I swivel the compound I can't access one of the bolt so I'd have to do with 2 or 3 bolts depending on the access. I can mill the top ends flat until it's level with the counterbore's floor. Then I can make a short allen wrench to get to the bolts.
