My Rockwell 14 X 40 Lathe
  • Thread starter Thread starter 4GSR
  • Start date Start date
if you need any other clarification, let me know. There was only one set screw , on the opposing side was a hole for a spanner wrench to loosen the part. Oh shoot, just realized I did not give the diameter of the boss. Get that tomorrow, it was about one quarter inch wide.
The overall width of the part is about .927 inch , I did not clean so actual is prob .925".
John,
THANK YOU KINDLY!!!
That is what I need. I didn't expect you to pull it off your lathe, but I greatly appreciate it.:):dancing banana:
Ken
Will do.
One thing that does come to mind is the clutch brake used on this lathe. The Conway Clutch company that used to make these is not in business anymore.
Does anyone know of a replacement clutch brake or parts for a existing one are available from another company?
I don't have a brake , don't know.........
The lever that you engage the clutch with, when pushed the other direction past neutral should engage the brake and stop the spindle quickly. Might need adjust the brake side of the clutch to get it to work.
