- Nov 29, 2017
- 552
If you don't have a collet in the spindle you're probably hearing the drawbar rattling around.and there's nose when the spindle is spinning and when I'm retracting the quill at the same time
Now, I'm trying to figure out why my X axis get extremely tight when I reach towards the end of when the table is going left.
Maybe 4/5 of the way of when the table is going towards the left, it starts getting tight.
The gib goes into the left side of the table. I have the gib screw on the right side all the way in, which loosens and makes it a lot easier to turn, but still have the same issue when moving the table to the left. The only time I don't have this issue is when I have the gib completely out.
I notice that the gib has gouge marks on the front and on the back. I'm assuming this is for the way oil to get trapped in.
What was the resolution of the high range engagement problem?
I’m seriously considering one of these mills.
I'm familiar with the operation of Bridgeport style mills.......31 years in a commercial shop. I was interested in why he was having problems.The gear just doesn't pop in unless you turn the gear with the belts just a bit. Once it drops in you hear a thunk. Mine had some issues with the gear dropping in below freezing. Just too cold. I had to play with it a bit.
Yeah, I just had to move the belt after turning the cam lever forward until I hear it drop before turning the lever to high gear
I guess I have to remove the table and clean up everything. There's a power feed on the right side. I hope all I have to do is remove the handle on the left, then unscrew the lead screw from the right side all the way out. I don't wanna have to take the power feed off
