Reductions are easy. Here are some examples.
Drive gear has 12 teeth, driven gear has 48 teeth. 48 divided by 12 is 4, meaning that the reduction is 4:1 The driven gear will turn 1/4 the speed of the drive gear.
Another way to arrive at the same conclusion: 12 teeth divided by 48 teeth equals .25 meaning that the driven gear will turn at 1/4 the speed of the drive gear.
Now, if you have multiple reduction ratios, let's say the first reduction is 4:1, the second reduction is 3:1, and there is a third reduction of 2.5:1 you can calculate the total reduction by multiplying all of the ratios as follows:
4 x 3 x 2.5 = 30 meaning the overall reduction is 30:1. The final drive speed of the spool would be 1/30 the speed of the input to the first reduction. If the engine speed was 6000 RPM, and the overall reduction was 30:1, then the spool speed would be 200 RPM.
Inversely, if the engine puts out a torque of 100 in/lbs, the torque after reduction would be 30 times greater, or 3000 in/lbs which equals 250 ft/lbs
