- Nov 17, 2017
- 1,525
Looks a lot like a Grizzly G0730
This is my first entry to this forum, in fact I joined just so that I could respond to your posting.Well this is my first post in this forum. Have been posting in the Clausing forum...
About $240, how much did you pay?The tooling is what sealed the deal.
So what does everyone think this deal was worth? Just curious. I will go into details after hearing some quotes.
By the way, I paid $2500About $240, how much did you pay?
Bob,Sorry to Peter not responding sooner. Crazy time of the year. Decided not to do any cleaning or restoration on the mill right now since it is still functional. Will make a base with wheels to get into back corner of the shop next to my lathe. May be next winter project.
I have just scanned in my original 'SELECT 1/2V Vertical Milling Machine' Service Manual (free...) and attach as a 40MB PDF. I suggest everyone should also download the 'Grizzly G1004 Instruction Manual'.
Grizzly still have some G1004 parts available which should be interchangeable with the Select 1/2V mill. Item# in SELECT Service Manual matches Grizzly online parts list which is an 'A1S' style mill.
Grizzly G1004 Online Parts List
---- A few questions ----
1. Have not figured out how to get the fine spindle feed to work. Not sure about the knurled knob on the left side. Loosen but not sure some thing is suppose to slide?
2. Any recommend DRO scales to uses on this mill?
3. Will need to get a decent vise. Any suggestions? Have been watching used Kurt D60, D601, D675 vises on eBay.
Thanks every one...
Bob G.
What I figured out so far on my mail is that loosening that knurled knob to the point just before the spring inside pushes it off disengages that wheel on the front left which is the fine quill feed. With the knob backed out like this, the quill lever on the right side should activate the quill just like a basic drill press. Tighten the knurled knob all the way by hand to engage the fine quill feed, which is that hand wheel on the front left above the quill.1. Have not figured out how to get the fine spindle feed to work. Not sure about the knurled knob on the left side. Loosen but not sure some thing is suppose to slide?
