I have an 18 kBtu Mr. Cool in my 300 sq. ft. attic workroom space. I also have four 1 Kw baseboard heater. Although the space is insulated from the remainder house, the chimney from the wood burning furnace runs through the middle of the room and in coldest wether will keep the room at 55-60ºF. I only turn on the baseboard heat if I am working up there and the Mr. Cool in heat pump mode if it is above freezing. Mr. Cool states in their operation manual that heat pump performance may be poor if operated below 45ºF outside temperature.
AFAIK, only the DIY series comes with precharged lines compressor. All other will require a pump-down with a vacuum pump and system charging. One should also note that if the system requires pump-down and charging that some municipalities require installation be done by a certified HVAC person. Although I have the equipment and knowledge to install such a system, I chose the DIY version because my compressor is not at gtound level and I chose not to have to mess around with making relatively more complicated connections, pump-down, and charging.
