It's called an atmospheric intake. On the intake stroke when the piston is moving down it creates a vacuum in the cylinder causing the intake valve to open thus sucking in a charge from the carburetor.
I hope this helps.
Pat
It was a combination of several things.
The intake spring was too stiff. I replaced it with a spring much weaker that I never thought would work... but its fine.
I machined a hex on the flywheel so as to use a drill to turn it and that helped a lot.
Then, timing and carb adjustments helped make it better.
It still wont start by hand but I'll keep making adjustments. Starts fine with the starter drill.
