So if your going to do lite milling on a lathe, like this, a 2 flute end mill set is a better choice than a 4?
Just checking as I intend to do similar stuff and have no end mills yet.
I also recall something about step climbing the mill is a no no. Something to do with only taking cuts in one direction depending on the way the bit is spinning to prevent pulling the work out of the clamp?
