Yep, runs great.
What the pictures may not show is that the crank centerline is above the centerline of the cylinder which causes the incoming air to "leak" around the piston during most of the revolution because the piston is tilted in the cylinder.
And it will only run one direction, if I spin it the other way it will bounce back and take off in IT'S "right" direction.
It runs surprising slow with only the slightest air pressure, but sadly it will not run on a fishtank airpump.
Joe
Joe
