As already pointed out, no oilers on the ram, just brush a little way oil in the dovetails and and give it a slide through its range every now and then. When you pull the ram, be very careful if using the lift eye( if it has one on it ). Take the eye out and inspect it, and the threads in the ram casting to be sure they're in good shape. And be see that the eye is threaded well into the hole, and the shoulder is seated against the mating surface. Granted, you're not lifting the entire mill with it, but still a good practice to get into. Never trust a lift point you didn't inspect/install yourself. And personally, I never use lifting hardware with "Made in China" on it. Much prefer seeing Crosby USA on the forging.
