- Jan 22, 2012
- 655
Thats the same one I have. I use to sharpen bits by hand with good results, but this baby makes them better than new. There is a "feel" when using this tool, for the guys that don't like em, try it again. If you want to get years of service out of the collets and tool, blow them out often with shop air, keep the abrasive grit from the plastic contact points.
I must be one of the clueless ones as I have one (750 model) and never felt the results cut as good as doing it free hand on the bench grinder. It works ok on the small bits that are hard to do manually but not so much on bigger bits (any size above 1/4"). If there is a secret to it I'm all ears. If you were closer I'd come over and get schooled but currently I'm a bit too far away for that.
