OK, for the next little piece of the puzzle, I made this little yoke. Overall not a very interesting part, but required some work holding thought.
I need to machine all 6 sides of the cube, so how to do that in the most efficient manor and still be able to hang onto the part. The final part is about 2'' x 1.625'' x 1''.
So start with a 2 1/4 x 1 3/4 x 1 1/4 piece to make sure you have material to remove all the way around. I normally leave at least 1/8 inch all the way around so I don't come up short.
Profile the outside to 1.030 depth. This is 0.030'' deeper that the final width of the part. Allows a burr free cleanup on the other side. This also leaves about 1/4 inch of material in the vice to hang onto the part. As noted in a previous post above I have a 14° dovetail cut on the vice jaws, really hangs onto the part.
Once that operation is complete, drill & ream the 0.375 hole.
Now flip the part over and face off the excess material.
Then flip the part up and machine the slot. In all cases machining was done with a 3/8'' 3 flute aluminum cutting carbide end mill, about 2500 RPM, 10 IPM feed, tooth load about 0.0015'', 0.375'' stepdown, 0.150'' stepover/pass, using a trochoidal cutting strategy for efficient tool loading. X and Y zero were set at the vice stop for the entire job, only the Z zero changed as needed. Total spindle time was about 35 minutes. (and about 3 hours of setup and CAM time)
Thinking through the entire process before ever making a chip saves a lot of time in the end and you don't paint yourself into a corner.
Drill the two 1/4'' mounting holes and done.
