My Craftsman 12" X 36" Barn Find
Robert,
It opens the photo library with 32 pages of photo's.
I don't want to have to look thru 32 pages to find them.
Any way to just put them in the thread?
Mike,
It wouldn't help to look through 32 pages anyway. Until the Who Can View is fixed, you can't view the album, either. It should be an easy fix only taking a few minutes. And for Joe to go back and upload everything would take him probably several hours. Which I don't suggest he does unless it turns out that the settings cannot be edited by anyone.
Joe,
The Photo viewing problem is that your album is set to PRIVATE. Specifically, the View By or Who Can View or whatever it's called is set to Owner. Go to your Album and see whether or not you can figure out how to change the setting. But I tried with my only album and couldn't figure out how to change anything in mine except the album title. So probably you are going to have to send a PM to one of the Admins, Nels is his User ID, and ask him to change the Who Can View from Owner to either Member or Everyone or whatever the appropriate description is.
If I could have figured out how to do my own, I would have logged in as you and fixed it just now. But I couldn't so I didn't.
If you select "Your Albums" on the left side it will show you all of your albums. Select the small white square in the upper left of the album and a drop down menu will appear. Select "Other Actions" and a sub menu will show with one of the choices being "Moderation Actions/Change Privacy of Albums" . Select that and a popup will appear with the choices to change all or just one album to what you wish>
Hope that works for you.
Wierd Harold
I can see the pictures now.
Awesome looking lathe Joe.
Now I know where to mount my Tach pickup sensor. Just need to find a magnet small enough to fit behind that gear on the spindle. Mine didn't have the 3mm magnet with it and the ones I have are 12mm. To big to fit there. Also good place for the Tach. I was just kind of hesitant drilling into the cover.
Harold,
Thanks! I knew it was there somewhere because I know I found it a couple of years ago. And I should have known it would be a check box because that's the way that you do similar actions with posts and downloads. Grrr!
I didn't want to drill the cover either, but the previous owner had the barrel switch mounted there so I just used the existing holes. Actually, he (she?) didn't do a good job of drilling the holes (they don't line up, they are over 1/4" out of horizontal!!) but this whole deal covers that all up so I killed two birds with one stone!
I can see the pics now. Very nice! The reverse lockout is a great idea!
Don't reach out for anything on the shelf or wall behind the lathe while it is running!! Even the slightest contact of your clothing with anything turning could become a medical disaster in a micro-second. That is why I have nothing on the wall behind my lathe. No temptations.
Spiral_Chips
The pictures are a little deceiving, there is actually a 3' path/hallway behind the lathe, but currently there is some mobile carts in the path. They have since been moved, but you are exactly right.
