[QUOTE="
Put the jaws on, chuck a piece of like sized material, (turn it so that is reasonably round first) indicate and adjust the chuck to whatever tolerance is required, expect .002-.005 TIR runout between parts as anything else is asking entirely too much of a scroll chuck. With practice adjusting the chuck will take less then 10 minutes unless you suffer from crippling OCD of course (-:
Thanks Wreck Wreck, How do you adjust the jaws on a scroll chuck? Regardless of which chuck key hole I try to adjust, the TIR error is the same?
Joe[/QUOTE]
You must have an adjustable chuck, you are adjusting the entire chuck body not the jaws themselves, Set Tru is a brand name owned by one of the chuck manufacturers, I am not sure which one.
Adjusting a set tru chuck is exactly like putting a scroll chuck in a 4 jaw independent chuck and dialing out the runout with the independent chuck, the errors in the scroll will remain however. If you require tenths accuracy dial in each part and finish it in one chucking, or stop chasing tenths (-:
I only chase tenths when I know that the Customer has the ability to measure it and the part requires it.
I routinely get drawings for lathe parts from one particular customer with dimensions like so (last weeks parts, a counterbore) .8749-.8744, .213 deep +- .002.
There is zero chance that anyone at this company can measure this, or would even try, chasing tenths will drive you mad so don't do it.
