- May 10, 2012
- 997
The early spindle housing I had used grease lubrication with grease fittings. The later ones used oil lubrication. I changed the spindle housing since the original one had a bunch of milling done on the top of it. I think tapered roller bearings don't care for the most part, most bearing manufacturers specify a different speed range for grease or oil lubrication. It was just easier to put oil in than grease in this spindle
