- Dec 8, 2013
- 2,651
I'm modifying an Avey MA-6 drill press[1] for milling. The quill has an MT3 taper, no drawbar. Obivously, for milling I need some way to retain a shank. The usual method of drilling the splined shaft is out: the shaft is three feet long. I've come up with several possible solutions, but they depend on knowing the exact dimensions of a drawbar-type MT3 shank. So: how far up into the quill will the top of such a shank be, and how deep is the threaded hole in it? Is this reasonably standardized? I don't have any such shanks and can't afford to buy tooling that I might never be able to use.
[1] This is not your typical Chinese drill press. It weighs about as much as your Bridgeport, is seven feet tall, and has a knee-mounted table that could seat a family of four. The column is cast iron and has about a square foot of cross-section.
