- Oct 20, 2014
- 494
Thanks to Tony, I have been able to move on with this project. Been out of town awhile, but I'm back now, and have some shop time.
I rotated the chuck by hand to cut the taper, using the reamers Tony sent me. They worked perfectly!
I have a really nice MT2 taper on the workpiece. I needed to make a lathe dog to turn it between centers. For that, I dug out an HSS tool, sharpened it up, and literally plowed it through the work. It was cutting, not screeching, right at the edge of chatter. Dark, dark, dark chips, and the reek of sulphur based cutting oil.
Who don't love the sight of a lathe workpiece smoking like crazy? Here's the lathe porn.
Just because.
Many, many, many thanks to Tony for loaning me the MT2 reamers. They worked perfectly. I reamed the taper by hand, taking my time. Once it fit well, I faced off the workpiece until it had the same stickout as the MT2 of the tailstock. Just eyeballed it. Then I flipped the workpiece, faced the end, and drilled it through. I then turned a cylinder so I could make a lathe dog to turn the workpiece between centers, an that's where I'm at now. Tomorrow I'll disassemble the Atlas spindle, and start turning the workpiece between centers to rough dimensions. I'll need to make a toolpost grinder to get it right where I want to be as far as dimensions go.
All in all, it's been a dang enjoyable day in the shop. Coffee, a good cigar, a touch of vodka (after everything was done), and plenty of smoke from the workpiece. That SB9A is working to earn it's keep.
More pics as the job progresses. Again, Thanks Tony! You've really helped this project along!
Just because.
