- Nov 25, 2015
- 10,041
@C-Bag thank you. Great idea.
I took the head off, propped the end of the quill on some heavy parallels, fit the fork, I had to grind / file it open to fit.. Which was what I wanted a good fit. And it took quite a number of blows to loosen it. I don't think the bearings took the force by propping the quill the way I did. When I was banging on the draw bar last night I do believe I may have brinelled the bearings. That was a lot of force. I am done for the day. The last few days have had too many issues, one thing after another. So I can relax. I will build a new draw bar. I like the way mine is setup so it self ejects the taper. Not sure why this one jammed up. I stuck my finger up, nothing up there, I can't see anything, the holder was clean. There were not enough threads in my opinion engaged. My new draw bar will be longer. I may also go to a hex on top vs a square, thinking that there would be more surface area, and less prone to twisting.
I have some 12L14 but considering using 1144 for the new draw bar. I have to silver solder a washer onto the end to make it work with the topper on the quill.
@DAT510 yep, thanks, but I was very familiar with them. I have made my own in the past for servicing some chucks. Just then I had a mill.. I was not looking forward to sanding the taper ...
BTW the hf forks are soft. The end mill holder cut into the metal of the fork. My old forks never had that happen. I am sure they were drop forged, these may have been cast. Of course now that I am relaxed, I think I have an idea where my tie rod fork is... But for $10 I am not going to complain.
As far as bearings, I hope I don't need them. I would have to find NOS. Years ago a guy on here posted about replacing them, we had pm'd back and forth, and his solution was to find a looser class of bearing. A c3 if I remember. I would not want to go to a looser bearing. I want to keep it tight.
