Guys I finally got around to getting a sleeve/reducer for my lathe but! Its a 1 1/4 OD/MT#3 which is great I think.The OD that I need is 1" to fit the turret but I receive info that I could take an 1 1/4 sleeve turn it down to 1" which then all my #3 MT drill chucks and live center with work.OK here's my problem,taking a few passes I notice that about first 1/2 all is good then it seems that I hit the harden area or harder area plus an interrupting cut and after the interrupting cut its seems its harder.Well my question is,do I have the right carbide cutting insert for turning down this harden sleeve?If not could someone direct me to what I need to order?This is an AXA tool holder and tooling set that I pick up from Shars and the insert is what came with it.I am lubing the part,hand feeding slowly at a low rpm setting.Thanks for any advice
View attachment 304739View attachment 304740
