- Feb 2, 2014
- 1,263
Thank you for your offer but I don't think it will be a problem. The bottom half of the yoke is immersed in 90 weight oil when stopped and the clutch housing throws the oil everywhere when it is running. The slot in the yolk is 0.125 wider than the land and the center hole is 0.200 larger then the small diameter of the collar. The yolk does not ride on the collar except for releasing or applying the hand clutch as the forks hold the yolk up centering it away from the shaft in both up and down and left and right directions.
Thanks
Ray
Thanks
Ray
