- May 7, 2015
- 269
Yes, that is what I will do then, Yes when I was mounting my DRO on my mill I cut off some bolt heads off the bolts and ground the ends to a point and used that as a blind hole transfer punch. But in the case of the lathe adapter, if I need to I would purchase the more accurate ones.
Thanks Jim,
Does it matter if I face the adapter and then turn the register to size or the other way around as you indicated?
Thanks for all of the help.
We have a vacation home up in Olympia WA. Next time we drive up I will have to stop and buy you a cool beverage.
Joe
Thanks Jim,
Joe
