It was sort of dealt with above, but to summarize bearings and such act differently under load than when coasting, even when the motor is in a 'no load' condition, internally it is still loaded. Wiring with current running through it moves via magnetic induction. Magnetic fields changing move wires and ferrous metals. Even a simple induction motor has a lot of places that could cause vibrations. For our big industrial motors we see them move quite a bit when powered up vs. resting, so couplings are best installed based on the running shaft position, not the resting position. Smaller scale, but it still happens in little motors.Maybe one of you Electrical gurus out there can give some insight as to why this motor would vibrate while supplied with electricity, but stop vibrating when current is switched off even though it is still spinning fast. Thanks, JR49
could rubber mounts be used on a drill press if the bolt is also buried in the rubber so there is no steel to steel contact?
