Many years ago I pulled wrenches on heavy equipment and trucks. I had to roll my tool cabinet out of the shop and onto the asphalt to get to some of the equipment. Rolling heavy tool cabinets with those stock wheels onto irregular surfaces was difficult. One of the older guys (this was when I was still a pup) helped me to install some old steel wheel casters from a dumpster under my box. That thing rolled so nice on uneven surfaces.
You are going to be carrying a lot of weight and top heavy to boot. If you plan to roll your box out of the garage and off of that smooth floor surface, you may want to think about replacing the casters with steel wheels.
Looks great. I really like how you incorporate a standard tool box.Since creating the green cart, I have made a red one, and there are improvements.
Love this. I had thought about it some time ago, but hadn't done anything about it. This just confirms the idea and love the upgrades that you have made. I have always assembled small tool bags and boxes for specific tasks, Electronic/Soldering/Etc, Plumbing, Etc. But for welding/fab work you need a lot more, brushes, hammers, clamps, consumables, etc, etc, etc. I hate looking for tools.Since creating the green cart, I have made a red one, and there are improvements. I don't think I've posted about it here. Apologies if I have.
1. I made one set of casters farther apart than the others. In addition to making it harder for the center of mass to go past all the wheels, it discourages the cart from rocking, and rocking leads to tipping. Trapezoidal things hate to rock. I'm going to go back and add this feature to the green cart.
2. I made the bottle restraint lower at around 20" off the deck. The restraint on the first cart is fine for tall tanks, but it's too high for small ones. In retrospect, 18" would have been better. A low restraint will work with tall tanks.
3. Instead of using long, needlessly strong, distortion-inducing welds to fill in corners and make everything pretty, I filled some of the corners in with JB Weld Steelstik putty.
4. To make attachment points for the bottle chains, I just welded whole chain links to the bottle restraint. I didn't drill any holes.
5. I shortened the wheelbase so the cart would turn in a smaller space.
6. One of the machines is a plasma cutter, so I made a support to hold the "toilet paper" filter at about eye level. No more leaving it on the floor.
I got a piece of 3/4" plywood, and I'm going to cut it to fit the top of the box and paint it. The sheet metal top is okay for light machines, but fat American machines really need something stiffer.
These carts are absolutely fantastic. A joy to use. I do a little machining here and there, but fabricating has changed my life more than anything.
One thing I would add to mine is a rack for 3-5 4.5" grinders with different discs onto the back. Don't care for cordless so the hanging rack would include proper storage for the cords. Another rack is for long bar clamps.
