- Nov 5, 2016
- 1,420
I'd say that's definitely worth a try! Anything to give you a good profile for properly shaping the tool.I don’t have a 3d printer either but what popped into my head was using some JB WELD Steel stick epoxy putty years ago. I could see taking a batch and mixing it up then squeezing it into a couple of splines that had like Fluid film on it so it wouldn’t stick and let it set up. Then slicing it like you did with your gauge. Then it’s the tool grinder then the bench grinder.
Ted
