I recently embarked on a project to fine tune the alignment of my lathe in preparation for my most ambitious project to date, WRT to accuracy. Previously, I've only been working to "farmer-repair" accuracy levels. Now I want to turn some parts to real fine accuracy.
I have the headstock aligned now. That was a big job, but it's done, and its nearly perfect.
I've finished alignment of the tailstock. It's about as good as I can get it, with about .001" horizontal variation when I unclamp the tailstock, move it 18 or 20 inches on the ways, and bring it back, re-clamp, and re-measure. It comes back to within about .001" (horizontally) of the same spot each time relative to the spindle, and within about .001" of matching the headstock centerline.
I also find that the tailstock centerline is about 10 to 12 thousandths above the centerline of the spindle. I've read a couple of places that this is intentional on the part of the manufacturer to allow for future wear. Is that correct?
I can understand how that vertical alignment error is not of serious concern if our turning/cutting tool is set on center, but my real question is what this means for center drilling operations. If the tailstock center is 12 thou. above the spindle center, will every center drilled hole be 24 thousandths oversize? Or will a drill tend to 'hunt' and find the center of the piece? Will the geometry of the center drilled hole still be correct to fit the tailstock center?
Can someone explain? I expect that once you explain this, the answer will be obvious, but my mind is getting twisted around the geometric implications, and I don't know which way it goes, and I can't seem to find this answer in a prevous thread.
