I picked up this knee mill on CL about a year ago. The P.O. had already installed the power feed on the X axis, a home made power draw bar and DRO. I have since refit the scales to the table for the X axis of the DRO, remounted the power feed to use the factory trough so I can insert T nuts from both sides of the table now and install a 3 phase motor with a HY VFD and Hall effect tachometer. I posted a few pictures in another thread but I didn’t want to high jack someone else’s thread so I figured I would start one for myself. Plus I have done a bunch of reading on this forum so I guess I shouldn’t be lurking any,ore and try to contribute.
The first thing I would like to share is the power draw bar. It is pretty ingenious. The P.O. to.d me he had copied the idea from somewhere off the internet so I am not really sure where the credit belongs. I can say it doesn’t belong to me as I bought the machine this way, but I can say it works flawlessly. There is no way I would have the patients to change tooling with wrenches, especially since there is no way I know of to lock the spindle from turning.
This system simply uses a butterfly impact that rides on two guides and is spring loaded so when you let go of the handle it pops up out of the way. Depending on what direction you move the handle the impact tightens or loosens the draw bar.
