- Dec 18, 2019
- 7,729
I made (and have used) a tool to cut inside threads. It can be either right or left handed by changing the HSS tool bit. Have cut threads with the plunge method and they came out ok, but that was in 6061. I need to thread 4140 and was thinking of using the compound and modified flank cutting. I know how to do this for external threading, but get confused when thinking about internal threading. Since everyone's lathe is a little different, let's use 29.5 degrees (rather than 60.5) as the reference. Is it the same set up as external threading? (Except adjusting the compound towards the back.) I will be cutting RH threads in reverse with a LH tool away from the chuck.
